Directories HelpNAV
The directories options
Incoming Files
Specifies the directory to which completed downloads are moved. If the default path is changed an existing folder must be entered. eMule will not create this directory. You can override this setting per category by choosing a different Incoming Files folder. Please note that your Incoming Files folder will be shared.
Temporary Files
This option specifies the directory, or directories, where the downloads in progress are stored. Because of the multi threaded download system, eMule creates dummy files (*.part) of the size the finished download will have. You can configure eMule to use only the size the file currently has by enabling the 'Sparse' option in Extended (only works on NTFS filesystems, the Windows XP default).
You can add multiple directories by clicking the [+] button, next to the browse button. Temporary files will be distributed randomly among these directories. This allows you to use multiple harddisks for temporary files, should you be running low on storage.
eMule has to be restarted before any changes to its directories will take effect.
Shared directories
These folders will be shared in the network and a list of them may be retrieved by eD2k clients if they use their friends feature (depends on setting in Preferences -> Files). If you want to share all subfolders hold down the CTRL key while clicking on the parent folder. This does not work for whole drives/partitions.
o UNC Folders
UNC stands for Uniform Naming Convention. It is common way to access shared resources (folders or entire drives) in a network without having to map this resource. All UNC folders follow this format:
\\server\resource\...
Example:
\\fileserver\share\eMule would point to the folder eMule on the shared disk with the name share of a computer called fileserver.
Some notes on sharing files:
Whenever an eMule client connects to a server it transfers a list of the shared files. The server stores this list and makes it available for search or source requests. This file management puts CPU load on the server, the more files, the higher the load and consequently less users the server can cope with.
Please follow these guidelines when sharing in this network:
> Your Incoming and Temporary directory are always shared so do not add them.
> The eDonkey network is not well suited for sharing large number of individual or small files, such as whole mp3 collections. Zip your files if you are sharing them.
> Please don't share directories like \Program Files, \Temp, or \Windows nor entire disks.
Applies to version: 0.47c +
Last update on: 2006-09-16 by TubularBell
Translate this page Last Update: 18.09.2006 0:16
Display
Connection
Directories
Files
Notification
Statistics
Messages and Comments
Scheduler
Security
Extended
