Messages and Comments HelpNAV
Messages
Unwanted messages can be blocked by entering them in this filed. If the text matches no messages will be displayed. Multiple messages may be chained using | as separator.
o Accept from friends only
All messages except from users added to the friends list will be blocked.
o Accept from valid clients only
This setting makes sure, that messages are only accepted, if the sender client is valid and does not appear to be a fake. This setting should be turned on.
o Advanced Spam Filter
The Advanced Spam Filter will check every incoming message. If any of the following filter criteria is met, the sender of the message will be ignored. A spam ignore will last for the current session only.
> A webadress or URL is sent on first contact
> The user already sent 5 messages without receiving a reply
Users on the friends list will never be marked as spammer.
o Show Smileys
If checked, eMule will replace text smileys like :-) with graphic smileys like smile.gif .
Comment
This functions works like the message block above but is applied to file comments
o Indicate downloads with comments/ratings by icon
For all files which have a known comment or rating, an icon will be shown in front of the filename which indicates the result of the rating (from red for bad to green for excellent).
Note: File comments should help other users to judge the quality of a download. They are not intend to talk about the weather or for advertisements of any sort. Please leave proper comments.
Translate this page Last Update: 31.10.2007 16:33
Display
Connection
Directories
Files
Notification
Statistics
Scheduler
Security
Extended
