Lucent CellPipe 20A-GX-E HelpNAV
Follow these simple steps to configure your Lucent CellPipe for eMule. This setup assumes you have a PPPOE connection like DSL running.
Start a telnet session with your routers IP. To do so
a) Use the Windows Hyper Terminal and type in a Name (does not matter which) for the new session, choose TCP/IP (Winsock) as connection type then enter your router's IP as the host address
  or
  b) Go to Start -> Run -> telnet router's IP
In the telent sessions that starts enter these commands each on a single line:
  pat addpatin pppoe 4662/tcp client's IP
pat addpatin pppoe 4672/udp client's IP
save
Router's IP is the IP address of your CellPipe router and client's IP is the IP address of your computer running eMule.
Many thanks to Jarek for this how to.
Translate this page Last Update: 23.07.2003 13:23
Routers
Linksys BEFSR41
US Robotics Model #8000-02
  Ports
