Emule On Linux With Wine Mini-howto HelpNAV
eMule on Linux with Wine mini-HOWTO
Revision 2.5 (June 29, 2007)
Maintainer: mindpirate
Contributors: Painkiller Jane
PREREQUISITES
    This document assumes you have a recent Linux installation with an X11-based window manager or desktop environment such as KDE, GNOME, or Xfce.
INSTALLING WINE
INSTALLING EMULE
    Download the latest eMule installation executable and save it to your home directory (shell alias "~" under most Linux setups). Launch the executable from a terminal:
    CODE
    wine ~/eMule0.48a-Installer.exe
    Wine will first create an emulated Windows environment in ~/.wine then launch the installer. Proceed with the eMule installation as you would under Windows.
UNINSTALLING EMULE
    To remove eMule from your emulated Windows environment, type the following in a terminal:
    CODE
    uninstaller
    Select eMule from the program list and click Uninstall.
LAUNCHING EMULE
    Two options for launching eMule are provided here.
    On Linux systems eMule's UploadSpeedSense feature presents users with a security tradeoff since it uses ICMP packets for pinging, something which Linux requires root privileges for. Because of this, if you wish to use UploadSpeedSense you must use eMule under less local security restrictions than you would normally run Linux applications under. Although this risk is not greater than the risk running eMule under a real Windows installation presents, it still means that your entire system can be compromised if an ICMP vulnerability is exploited.
    So what is UploadSpeedSense? From the eMule preferences documentation:
    QUOTE
    USS is a function to monitor the ping times of the connection and to automatically adjust eMule's upload according to this ping value. This ensures that the connection never cloggs [sic] and will try to keep surfing and online gaming fluid.
    If you want UploadSpeedSense functionality and understand the risks, use Method 1 below to launch eMule, otherwise use Method 2.
    Method 1
      From a terminal invoke Wine via sudo like so:
      CODE
      sudo wine ~/.wine/drive_c/Program\ Files/eMule/emule.exe
      sudo will then prompt you for the password of your root account. Enter the password and eMule will launch.
    Method 2
      During installation the eMule icon may or may not have been successfully installed by Wine to your Linux desktop's launch menu. If you see the eMule icon there, simply click on it. If not, launch eMule from the terminal:
      CODE
    When launched for the first time, eMule will prompt you for some initial configuration preferences as usual. When it asks you what version of Windows you're using, select the "Win2K/XP" option so that your Max. connections won't be limited to 100 by default.
TIPS
  • To minimize the risk of .met/.dat corruption in the event of a crash, set Extended --> Safe .met/.dat file writing in eMule's Options dialog to "Always".
TROUBLESHOOTING
    There may be areas of the Windows API called by eMule that Wine won't handle correctly. If you notice any problems please report them in this thread.
KNOWN ISSUES
RESOURCES
Translate this page Last Update: 19.03.2004 15:09
Internet Worm Protection
Firewalled On Kad No More!
How To Avoid Fake Files
Ipfilter.dat And Guarding.p2p
A4af - What Does It Mean?
I Need A New Server.met File!
How To Filter Ips With Emule
Problematic Software List
