Strange Behaviour HelpNAV
"Strange Behaviour"
If problems with updating the serverlist or lost settings arise some configuration files may be corrupted. This especially happens after crashes or after upgrading from modified versions of eMule. Deleting all *.met, *.ini and *.dat files in eMule's installation folder (do not delete your temp downloads!) may help with this problems. Quit eMule before deleting these files. After restart set the proper options in eMule's Preferences and restart again.
Translate this page Last Update: 01.08.2004 15:59
  Search Results
Error Messages
eD2k Links
Downloads
Strange Behaviour
Server Connection
Blacklisted
