Internet Worm Protection HelpNAV
Hi everyone
Learn to open tcp/udp emule ports in Internet Worm Protection (NAV 05)
Configure Norton Anti-Virus 2005
2 - Open Internet Worm Protection Options:
a. Near the top left corner, select the Options button:
user posted image
b. Then, in the left hand navigation panel, select Internet Worm Protection:
user posted image
3- Add emule.exe as a Trusted Application:
a. In the Internet Worm Protection options, select the Program Control button.
user posted image
The Program Control dialog appears.
b. Select the Add button.
user posted image
The Select a program dialog appears.
c. In the Program Files folder, browse to and open the emule folder>emule.exe.
A Program Control alert appears: What do you want to do?
e. In the What do you want to do? picklist, select Permit, then select the OK button.
user posted image
Continue......
Translate this page Last Update: 07.04.2006 17:31
Firewalled On Kad No More!
How To Avoid Fake Files
Ipfilter.dat And Guarding.p2p
A4af - What Does It Mean?
I Need A New Server.met File!
How To Filter Ips With Emule
Problematic Software List
