Getting And Keeping Reliable Server List And Ipfilter HelpNAV
To get a reliable server list free of fake ones, you can follow these steps
  1. Go to Options/Security
  2. Select Filter servers too
  3. In Update from URL, type:
    CÓDIGO
    http://emulepawcio.sourceforge.net/ipfilter.zip
  4. Click on Load.
  5. Go to Options/Server
  6. Set number of errors allowed before removing the server to 9
  7. Click List button that appears next to the option Auto update
  8. In Notepad, that is opened, write this line and remove all others if exists:
    http://www.peerates.net/servers.php
  9. Save changes in notepad
  10. Untick the options to update list of servers when connecting to new server and new client
  11. Click on Accept
  12. Go to servers window
  13. Remove all servers from static list
  14. Remove all servers from list
  15. In Update Server.met from URL, type the same URL you did in point #8
  16. Click on Update button
  17. If you have selected Autoconnect only to servers on static list add the servers you want to static list
  18. Double click on any server
If you are getting the list by first time, not having servers in your list, you can, obviously, avoid step #13 and 14.
If you don't want emule to reload list at startup, you can also avoid steps #7 to 9, but not harm in doing them anyway.
From time to time, when the file is updated, you should have to load ipfilter, steps #3 and 4. And every time you want you can also clean and reload server list steps #13 to 16
Translate this page Last Update: 01.11.2008 12:19
Internet Worm Protection
Firewalled On Kad No More!
How To Avoid Fake Files
Ipfilter.dat And Guarding.p2p
A4af - What Does It Mean?
I Need A New Server.met File!
How To Filter Ips With Emule
Problematic Software List
