Open/close Emule, At A Specified Time HelpNAV
Hi everyone
Some people come here, asking about an way to open/close emule, at a specified time. (spanish forum too)
This tutorial it's for help them. at least that is the intention.
I have proven it, and it works.
Subject : open/close emule at a specified time (windows scheduler).
Open emule, (we'll use windows scheduler).
How to
Step 1
user posted image
Step 2
The first step asks you to pick the program to run. You can select from the list, or click "Browse..." to select another program. You can actually pick pretty much any file (not just programs) to run. For example, if you want a particular Word document to open itself or if you want a specific mp3 to play at a certain time, find that file (through the "Browse..." window) and select it.(in this case, emule.exe)
user posted image
Step 3
After clicking "Next >", you'll have options of naming the task and choosing how often it will run. Choose these options and continue
user posted image
Step 4
The wizard will then ask you to enter a starting time and date.
user posted image
Step 5
The next step asks for your logon information (if you normally type in a user name and password to log in to your computer).
user posted image
Continue....
Translate this page Last Update: 03.04.2006 15:54
Internet Worm Protection
Firewalled On Kad No More!
How To Avoid Fake Files
Ipfilter.dat And Guarding.p2p
A4af - What Does It Mean?
I Need A New Server.met File!
How To Filter Ips With Emule
Problematic Software List
