How To Recover Corrupt Downloads HelpNAV
Since the original Guide How To Save "corrupt" Downloads!, by Birk, has become outdated same way as the original spanish version Recuperar con MetMedic las descargas desaparecidas, by risalan, I have translated, thanks Babelfish, the spanish more recent guide Recuperar con metFileRegenerator las descargas desaparecidas, por Bagusajalf
CITA(Bagusajalf)
metFileRegenerator recovers downloads from eDonkey, eMule and compatible clients. V1.4 requires the installation of Java Runtime Environment v1.4 or upper. In order to recover files greater than 4GB it is necessary to use v3.0.16 (8 of October, 2006) or later. Still developing.
When we added a download three archives are created in the eMule temp folder (\eMule\Temp\, by default):
xxx.part (the download itself), xxx.part.met (information on the parts - 9,28MB each one or less if one is the last one - of the downloading) and xxx.part.met.bak(a backup of xxx.part.met), being always "xxx" a number.
In some occasions, after an unexpected closing of eMule or the operating system, one or more archives xxx.part.met can get corrupted, thus disappearing its corresponding download in the eyelash Transfers from eMule and a message of error in the window of Log (eyelash Servers) like this:
01/06/2006 14:53:07: Error of version of part.met file! (001.part.met => (null))
or
01/06/2006 14:53:07: Error: 001.part.met () corrupt, impossible to load the file
"Horror! Our download is lost when it only lacked 0,15MB of 617,15MB... "(paraphrasing to risalan
wink.gif )
How to recover the missing downloads
/!\ Is important to make a backup of the temporary archives that we are going to manipulate, with the purpose of being able to return to the departure point in case that the first attempts are useless. /!\
Method 1
The simplest form and first that there is to try.
Without closing eMule move the file xxx.part.met.bak affected outside the directory \Temp(with the purpose of turning it "backup") and rename it to xxx.part.met
Close emule and copy to \Temp folder the renamed xxx.part.met, overwriting the existing one.
If it has not worked, then ...
Method 2
  • Select the file xxx.part of the missing Download. Press Next
  • The process of recovery of the download will begin. A bar will show you the progress.
  • If you have more downloads to recover, repeat the previous steps for every one.
  • Close metFileRegenerator, open eMule (it will code hash of the download that had disappeared). You will have two equal downloads (or several to pairs): cancel the new download that you added, leaving the recovered one.
  • You already can erase any backup that you did during the process. Make it carefully. dry.gif
  • If by means of this method you do not manage to recover the download and you obtain like result an error message that says: "download the file again and try MFR again" (yes, that message is so redundant), we will have to use...
Method 3
Step 1
If you do not know what download is the one that disappeared, find out what downlaoad that xxx.part belonged to.
It can be that the extension of command interpreter (eMule Shell Extension), that allows Windows explorer to show information on the content of the temporary archives of eMule, gives this information to you. It is enough with installing it and exploring the temp folder to see what download belongs each file. This information is in yellow globes (tooltips), the inferior bar of the window (the state bar), in the Vista "Details", among others.
Although a corrupt file part.met will not show information and the most likely is than it is not worth of anything since the information that shows about part is obtained from its corresponding part.met, clear...
Perhaps you can find that information in the corresponding archives xxx.part.met or xxx.part.met.bak, opening them with a hexadecimal editor (Ultraedit32 or WinHex) or even with a text editor like notepad.exe ( Notepad), but most often, in these cases, the file is empty or simply "it has disappeared".
Content of a file xxx.part.met. Opened with a hexadecimal editor
Another way is "to read" the file directly xxx.part, or examining it with a hexadecimal editor and looking for in its head or the final part some data that identifies it (Take care! If the file is great, is likely that the hexadecimal editor takes long time in opening it, being able even to temporarily block the computer), useful in case the download is a data file (zip, rar, iso, bin, pdf, etc...); or opening it with a media player like VideoLan Client (more info in Help and Support> Features> Preview Multimedia Files), usefull in case is a audio or video file.
If you do not manage to identify to what download belonged the orphaned xxx.part, then that download is really missing.
Step 2
Once identified, start a new download of that same file. Nosense it is "similar", has to have same hash that the original one.
If we press the secondary button of the mouse on this download and we select Details, or simply we leave the cursor on this download, we will be able to find out what (number of) file part belongs to it.
Once eMule has found sources for all the parts (they do not appear red parts in the bar) and in the Information of the download the scetion Joint of hashes available: say "Yes", or you have even downloaded a pair of megabytes of the file, stop the download and close eMule
Step 3
  • Open metFileRegenerator (requires to have Java Runtime Environment v1.4 o superior installed). Select Recovery. Press Next
  • Specify the temp directory of eMule where is xxx.part of the missing download. Press Next
  • Mark only:
    • Write file met recovered in the old format.
    Press Next
* Note: metFileRegenerator creates a directory in eMule temp folder called \MFRcache and so many xxx.part.met.old files as downloads you have recovered. After successfully recover all your downloads, you can erase them.
The eMule Morph mod includes, through the contextual menu that appears pressing with the secondary button of the mouse on a download, the option "Import parts to file" that is used indeed for the thing explained in this post.
After adding the same download that was disappeared, you select it this option and you choose the file xxx.part of the missing download. It can recover "great" downloads (files greater than 4GB).
In some cases the fatality can occur of all the list of downloads disappear. In this coarse, concrete, situation maintain the calm, verify in Options>Directories that the path specified for Temporary Files points to the right directory and restart eMule, to recover all our downloads. It is advisable to make a backup of the temporary files before restarting eMule.
Since in very rare occasions a download has disappeared form my list and it was long time ago that I underwent it for the last time, can have errors in the explanation that I have given of the process to recover downloads by lack of practice. I wait for your corrections. smile.gif
Greetings.
Thanks to Bagusajalf the original creator of this guide. If you think it is usefull, it can be moved to Quick Help and Guides. BTW after clenning mistakes in translation.
Translate this page Last Update: 27.02.2008 0:19
Internet Worm Protection
Firewalled On Kad No More!
How To Avoid Fake Files
Ipfilter.dat And Guarding.p2p
A4af - What Does It Mean?
I Need A New Server.met File!
How To Filter Ips With Emule
Problematic Software List
