Settings & Speed HelpNAV
> Can I turn on eMule, add the latest download and finish it 5 minutes later?
> Things that influence download
> What settings are the best?
> How can I increase my download speed ?
> What download rates may I expect?
> How large should the queue be?
No, surely not. As eMule is especially used for large files the network is at 100% load nearly all the time. There is a simple rule saying "The sum of all uploads in the network = the sum of all download". Large files need a lot of upload traffic and considering the average low upload rates of today's service providers, it is just natural that the downloads take their time.
eMule is a network about sharing files and not trading them. If you keep in mind the difference eMule is the app for you.
Top
Some factors that influence the download speed:
  • eMules settings
  • High ID (Firewall and router settings)
  • Duration of the eMule session
  • Number of sources for a download
  • Availability of single parts
  • Popularity of the download
Wrong settings in eMule (wrong limits, too many connections), a low ID and short session durations have a negative impact on download speed. Very popular files (new releases) and generally files with a low number of sources or bad part spreading also cause low download rates.
Top
What settings are the best ?
What settings are best for eMule is heavily dependant on the type and speed of your Internet connection and the operating system you use. You should always use the Wizard to set good default values. Most important is that you provide the correct values for your Internet connection and operating system.
Good settings for the widely spread DSL 512 / 128 would be
Windows 2000 / XP
Download capacity: 64 (= 512 / 8)
Upload capacity: 16 (= 128 / 8)
Download limit: none (remove the check mark)
Upload limit: 12
Hard Limit: 500
Max connections: 400
Max new connections / 5 sec: 30
Download about 6 to 20 files at the same time.
Windows 98 / ME
Download limit: none (remove the check)
Upload limit: 12
Hard Limit: 300
Max connections: 200
Max new connections / 5 sec: 20
Do not download more than 12 files at the same time.
If you use Upload SpeedSense in Options -> Extended then the best is to remove all check marks on the limits and let eMule manage the bandwidth. It will make sure that you have a maximum upload for maximum credit collecting and that other Internet applications like online games or surfing run smoothly.
Top
How can I increase my download speed?
Apart from the correct settings only the files you want to download decide the speed. To get a good average performance mind the following:
  • eMule should run for as long as possible. The longer the better - best to keep it always running.
  • Do not download only one file.
  • Get files with 150 or more sources.
  • Do not try to get the latest releases, at least not too soon.
  • Upload as much as possible to gain credits.
  • Do not watch eMule. It doesn't like it.
Top
What download rates may I expect? This too depends strongly on your connection speed and configuration. For a normal connection you can expect that if you feed a well configured eMule with some good files you usually get between 20 kB/s – 30 kB/s after some startup time. There will be times where it is much slower but there are also times you may reach 2 to 5 times this value.
Top
A long queue increases the effectiveness of the Credit system. Very high QR values do not mean that you will never download from these sources as there are many modifiers which cut down the waiting time.
Top
Translate this page Last Update: 18.11.2005 11:57
  Installation & Updates
Server, Connection & ID
Settings & Speed
Credits
Downloads & Shared Files
Using eMule
Misc
